Devices Connected to Flex Server
Alan
Alan Member ✭✭✭✭
edited March 2020 in SmartSDR for Windows
I understand the Flex Radio is a server.  I notice when various third-party programs startup, I see a pop-up on Smart SDR saying that "third party" has connected to ip xx.xx.xx.  The pop up then disappears.
Question.  Is there a way to see, at any time, what ip devices are connected to my Flex Radio?
  • Mike NN9DD
    Mike NN9DD Member ✭✭
    edited October 2019
    If you look on the CAT control panel. The bottom line for each comport tells you what service is using it Mike NN9DD
  • Alan
    Alan Member ✭✭✭✭
    edited June 2019
    Thanks.  I believe a number of third-party apps do not go through CAT.  It appears they connect directly to the Flex-Radio Server via IP ports.  That is what I am looking for.  An example would be FRStack.
    Alan
