Devices Connected to Flex Server
Alan
Member ✭✭✭✭
I understand the Flex Radio is a server. I notice when various third-party programs startup, I see a pop-up on Smart SDR saying that "third party" has connected to ip xx.xx.xx. The pop up then disappears.
Question. Is there a way to see, at any time, what ip devices are connected to my Flex Radio?
If you look on the CAT control panel. The bottom line for each comport tells you what service is using it Mike NN9DD0
Thanks. I believe a number of third-party apps do not go through CAT. It appears they connect directly to the Flex-Radio Server via IP ports. That is what I am looking for. An example would be FRStack.
Alan0
