Ethernet/WI FI not working together after latest update of SDR software
For the past 4 months, no issues with the Flex 6400 connected to the Ethernet port on my Laptop while I used the internet thru my WI FI card …. After the latest update everytime I try to use the internet it locks up the Flex screen and compiles a bunch of noise through my sound card to the speakers.
Anyone else have any problem with this? I wish I never would have went for the software update, now when I try to revert back to the previous software the condition continues.
Thanks.
Welcome!
  • Member ✭✭✭
    edited July 2019
    did you do the factory reset? for starters after install?
  • Member ✭✭
    edited June 2019
    Yes.... I did the factory reset.... followed the directions to a T to revert back to the previous software
  • Member ✭✭✭
    edited June 2019
    This is not a common problem people are having with the update.
    Check you ethernet connections and reset your modem.
  • Member ✭✭
    edited June 2019
    Already did... Used a new CAT 7 cable ... Same result. Time too open up a help desk ticket I guess.
  • Member ✭✭✭
    edited June 2019
    They will get you going...
