Flex 6500 will not connect Via WIFI hot spot
WB9IXS
I have been using my Maestro and 6500 running v2.4.9 in an internet remote operation for over a year now. As of this weekend I can no longer get the personal hot spot to find any radios. If I use the Maestro at home in a WIFI setup it works just fine. If I take the Maestro to a different WIFI location it will connect but states no radios are available. I am using an I-phone and ATT. I also tried an Android and still no radios available. So... I have come to the conclusion that the issue is not the personal Hot spot but instead if I try to use the Maestro away from my home internet , regular WIFI or personal Hot Spot, I can connect but always get the message NO RADIOS AVAILABLE.
What happened, it worked for a year and just stopped.
Jim
Jim
Jim - can you put some details on all this? Is the issue persistent after cold rebooting everything? When you can connect is that by LAN or also remote by a different WAN?
Obviously Something changed.
Since you can connect using something other than the hotspot, the finger is pointing to the hotspot or its provider.
Whether a change rolled out by your hotspot provider, that something that change is likely the source of the blocking of the traffic you need.
Break your networking situation(s) down into smaller and smaller bits until you find out where that change is.
Steve
K9ZW
Thanks for the response Steve
Yes the issue is there after a cold reboot. LAN works fine from my home however I tried a LAN connection at my daughters house and I could not connect to the radio. I did however connect to the LAN. I am not sure if a WI FI hot spot is considered a WAN. I have tried two different hot spots from two different phones and neither connected to the radio.
I don't know how to break down my networking anymore than I have already. I have proven that by using the network connection in my home whether it be hard wire or WI-FI the Maestro always finds the radio. Outside of my home no mater what I try the Maestro cannot find the radio.
Does this make sense?
That it in a nut shell.
Jim
Well I solved the problem. It was operator error. I asked Flex for some advise and Tim responded with a suggestion to check the SmartLink connection by opening the network setting in SmartLink. Then you click the test button and if the circle is green your in good shape. My test was green. However.... to get to this test I needed to sign into SmartLink. I think that I signed in about 18 months ago and never have done it again. So obviously [ I can say that now ] I was not signed into SmartLink so that is why there no link to the radio away from my home router. I am writing this because nowhere on the Maestro screen was there a message that stated you are not signed into SmartLink. For the last year or more I never had to sign in it always connected. So if you have any connection issues do what guys do the least ... read the manual ... it's all in there.
https://www.flexradio.com/downloads/smartlink-quick-start-guide-for-smartsdr-pdf/
Jim
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
