Maestro Microphone
Not quite, you can do it with a short adapter to change from 8 pin to modular which plugs into the back of the Maestro. You also need a power supply as flex does not provide enough for the microphone, Yaesu do one for the microphone It all works fine on mine0
Im not sure you are correct as the MD-100 comes with a reversible modular/foster cord. Also the MD-100 is a dynamic mic so why would I need a power supply that is required for an electret mic. Would only need to power the internal filtering in the MD-1000
You are sort of correct and wrong. The MD100 has the reversible plug and the modular end will go into the Maestro. You can use the Dynamic Mic but the PTT in the M100 is not your normal switch and needs power for it to work, more than the 6700 or Maestro can provide. You could push the MOX button which works fine. The M100 has dual elements Dynamic and Electret, you can choose either or both. Once you select electret you need the power supply which then works the M100 with any combination, works the PTT on the stand and illuminates the various lights on the microphone. The downside is that the Yaesu power supply only seems to work when plugged into the foster connector of the M100 cable. The adapter is needed for the Maestro but obviously not the Flex 6700. I am sure it could all be rewired with different plugs I just haven’t looked.0
If this is the MD-100A8X (Not the newer M-100) we are talking about, then it has a 500ohm dynamic mic, I cant see anything else in the schematic. The PTT is directly wired to the ptt switch & ptt lock to earth, the low cut and high emphasis circuits can be bypassed by a switch and this gives a direct connection from mic input to dynamic element. This combined with the dual purpose foster to modular cables supplied with the mic seem ideal for both the 6x00 front foster or Maestro modular connectors.
What mic(s) will work with the Maestro? I find the FHM-3 is not correct.
Gerry
Hi Gerry, The FHM-3 will work with the Maestro but needs a different cable from the one that plugs into the back of the radio. You can check with Flex sales to be sure that you get the correct cabling for your mic.
EDIT: Here is a link to the cable:
- 371 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 996 Third-Party Software
