Transmit question with WSJT-X
Golden23412
I am trying to get a 6400 up and running on Windows 2.4.9. Ultimately, I'm trying to use my Macbook Air (DogparkSDR, xdax, xcat), but for now, I just want reliable operation on my Windows machine.
Last night, I was getting FT8 QSOs on WSJT-X. I could see in SmartSDR when it was receiving and transmitting. During WSJT-X transmit, I could see RF power in SmartSDR was approaching 100 watts, and SWR is close to 1.4.
Now, when WSJT says it's in Transmit mode, I don't see any RF power or any flicker on the SWR meter.
In Dax, TX Stream is on.
In SmartSDR, DAX is set as primary transmit audio source.
When I click the Tune button in SmartSDR, it does show expected tuning RF power.
In WSJT-X, Test PTT appears to work as expected, by turning on MOX, but no RF power is shown.
I can't seem to figure out what's wrong. Can anyone point me in a good direction?
DAX turned on?0
So ptt is fine but essentially there is no tx audio when using WSJT. In the WSJT set up (from memory i think it is the Audio tab) have you correctly selected the TX Audio...I. e. The tx dax channel ?0
Yes, that's right. PTT seems fine (MOX comes on in SmartSDR when WSJT-X is transmitting).
Also, I can see audio in the P/CW window in SmartSDR when transmitting.
I saw some other references to similar behavior here in the board, and have rebooted both the radio and the PC to no avail.0 -
Ok, weird. Everything seems normal again. I don't know if it was something I clicked or not. The last thing I changed before it started working again was re-selecting Dax 1 in the SmartSDR waveform window for slice A (not in the TX settings).0
Rebooting the PC fixed the same problem I had this morning when resuming operation in the VHF contest.
(If you plan to transmit a lot (like in a contest) you might want to cut your power output back some since FT8 is a 100% duty cycle)
Rick WR0H0 -
Try this, may work or may not, I don't run ft8, I assume you have a mic profile setup for Ft8? On my 6400 , ver. 3, sometimes when I key to talk there is no transmit, radio keys but nothing out. So I click different mic profile and just talk into Mic and it worked, switched back to regular mic profile and all was good, done me that way once today. Just an idea!0
Several of the suggestion that has been given are okay;
Download J.H. Taylor K1JT Guide.
http://physics.princeton.edu/pulsar/K1JT/wsjtx-doc/wsjtx-main-2.0.1.html#RADIO
This is how I run my FT-8 configuration;
1.Download WSJT=X2.0 User Guide
2. On the Table of Content;
3. Go to Paragraph 4. Settings:
4. Follow all the instructions listed.
For example: Rig. Flexradio 6xxx
Serial Port; I use - localhost: 60001 or what ever port you want to use. And or a
Network Server: 127.0.0.1:60001 etc...
Everything else will lock out and you may not be able to change.
Except you must TEST CAT (if everything else is okay, it will turn GREEN)
Then TEST PTT. That will tell you that the PTT is working
5.On the AUDIO tab::
A. Sound card:
1.Input: DAX Audio RX 1 (or whatever RX you want to use)
2. Output: DAX Audio TX
Nothing else ... The rest of those tabs are self explanatory.
If it still does not work? Call Flex radio doctors (lol) and they will do it for you.
However, you now may want to check that DAX drivers are NOT corrupted. There are
several way to correct then, Tim Ellison and several others have written procedures to
do then. For example on Jul 1st 2016 Tim wrote "How to do a complete uninstall of SmartSDR
for Window PC." Someone else re-wrote "How to manually re-install DAX drivers." Dated 26 APR 19.
Hope this will get you going and hopefully understand a little more, how DAX works.
For some reason, sometimes I have the same thing. 6700 goes into xmit but no WSJT audio. I have to close WSJT and restart. then all works fine. Once running it does fine. I figure its something in WSJT-X but who knows. I did ok in the contest 8,880 points. Had a good opening to Spain this morn and one to the NW this evening.
I run ver 3 with Win7 and occasionally my DAX cuts out. I just toggle the DAX and 99% of the time it will start working again. If that fails than I restart WSJT . Also had same "issue" with ver 249. Also double check the slider on the right side of WSJT and make sure its not turned down too far. I keep mine set at abt -1db
good luck!
- 634 The Flea Market
- 135 SmartSDR+
- 198 DAX
- 42 Aurora
- 956 Maestro
- 299 Shack Infrastructure
- 211 Networking
