IQ stream not aligned to radio and skimmer wrong spot
ik2egl
skimmer give spots on wrong frequency: the skimmer spots are returned with a wrong frequency in the same band.
radio freq is 14.023, but on IQ is 14015
I notice that IQ stream is not aligned with radio freq,, add some picture to better understanding
I have found the same but think it has more to do with mode of the radio together with CAT emulation used by CWSkimmer. For wide band operation using DAX, together with Narrow Band TX, I have found using Slice Master to control CWSkimnmer to be perfect with wide band input and narrow band TX control. IMO, its not the radio, its the radio control from CWSkimmer. I mitigated with Slice Master since I wanted Spot reporting on the radio so did not look further. Tonight I will confirm what needs to be done without Slice Master.1
hi Dwaine, thanks for reply
by the way I am using the last 3.0.19 where slice master is not working (upgrade will be available in the future). Plse can you tell what you mean by
Narrow Band TX ?0 -
SliceMaster is now available with support for v3. I suggest you upgrade. Will solve your issue.
Andy
KU7T
- 384 Community Topics
- 650 The Flea Market
- 150 SmartSDR+
- 263 SmartSDR CAT
- 288 FLEX-8000 Signature Series
- 962 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 801 Peripherals & Station Integration
- 142 Amateur Radio Interests
