210/5000 problem frequency display.
edited April 2020 in SmartSDR for Windows
I use:
Asus Z97 PRO GAMER + Windows10 Card Version 1709
Flex 6500 SmartSDR V2.1.30
Since new installation of W10, I can not read the frequency anymore.
The size settings of the parameterization panel have no effect.image
All other displays are trouble free, only the frequency ...
thanks in advance
cordial 73
Jean-Pierre F1EDG
Welcome!
  • Member ✭✭✭
    edited June 2019
    Jean Pierre,
    In the downloads section is a font.  I would try installing that font.  Yours looks wrong.
    Mark - WS7M
  • Member ✭✭✭
    edited April 2020
    Check font size and/or screen size
    Chris
  • Member ✭✭✭
    edited February 2018
  • Administrator, FlexRadio Employee admin
    The font is wrong.  Install the NapoliSerial XLight font as described above.
  • Member ✭✭
    edited June 2019
    I'm having the same problem Jean-Pierre F1EDG at the top of this page ! I wet to FlexRadio Downloads but can't find NapoliSerial XLight Font  File . A little help please
    Ed N5DG
  • Member ✭✭
    edited June 2019
    I gave up to quick , FOUND IT
    Ed N5DG
  • Member
    edited March 2020
    Download font and installed, but not sure how to change font for the program.
    edited March 2020
    It happens automatically when the SmartSDR has been restarted.  If that does not resolve the issue, then I suspect there is a scaling (DPI) issue with the monitor you are using.  Especially if it is a very large and/or 4k monitor.
