210/5000 problem frequency display.
F1EDG
I use:
Asus Z97 PRO GAMER + Windows10 Card Version 1709
Flex 6500 SmartSDR V2.1.30
Since new installation of W10, I can not read the frequency anymore.
The size settings of the parameterization panel have no effect.
All other displays are trouble free, only the frequency ...
thanks in advance
cordial 73
Jean-Pierre F1EDG
I use:
thanks in advance
cordial 73
Jean-Pierre F1EDG
Jean Pierre,
In the downloads section is a font. I would try installing that font. Yours looks wrong.
Mark - WS7M0 -
Check font size and/or screen size
Chris0 -
The font is wrong. Install the NapoliSerial XLight font as described above.0
I'm having the same problem Jean-Pierre F1EDG at the top of this page ! I wet to FlexRadio Downloads but can't find NapoliSerial XLight Font File . A little help please
Ed N5DG0 -
I gave up to quick , FOUND IT
Ed N5DG0 -
Download font and installed, but not sure how to change font for the program.
It happens automatically when the SmartSDR has been restarted. If that does not resolve the issue, then I suspect there is a scaling (DPI) issue with the monitor you are using. Especially if it is a very large and/or 4k monitor.0
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
