T/R Relay noise with Antenna Tuner - 6600
Thanks!
John KD8K
You must be using v2.4.90
I'm currently using 3.0.19. I never used the tuner until recently, so I am not sure if it occurred on previous versions.
QSK with ATU engaged is not supported unless using a separate receive antenna. This is documented in the 3.0.19 user manual. Where you using QSK?0
The QSK enunciator is displayed with the tuner activated on a single antenna, so I assumed it was supported. Apparently this is not the case. I would much prefer that the tuner stay inline for receive to allow for CW QSK, but it is what it is.
Thanks.
John0 -
Flex sites potential performance issues when using QSK with single antenna with ATU engaged. I agree this is undesirable but I’m afraid this is how iQSK works with Flex. I did find a workaround but not sure it will work in V3. Try to change to another band then back . That forces QSK to work with ATU on my 6600M running 2.49.0
For those operating scenarios where I need to use the internal ATU I also don’t want to use QSK. So, the limitation of QSK not being available for single antenna ATU operation is not an issue for me. I can run the CW delay slider up high enough (typically around 175) to eliminate the annoying clicks from the T/R relay.
However, this solution is not ideal in that I then bump into the problem documented at https://community.flexradio.com/flexradio/topics/missing-first-element-in-sidetone. Missing the first element in the sidetone makes sending by hand a near impossibility. I need to minimize the CW delay in order to consistently hear the first sidetone element on a noisy band, and 175 is too high.
As I look at the release notes for V3 and V2.5 I don’t see any indication that the “missing first element in sidetone” issue has been addressed. I have yet to upgrade from 2.4.9 and, regardless of which way I go, it appears I will need to continue to choose between listening to the T/R relay clicks or sometimes/often missing the first element in the sidetone. This choice is one of those “rough edges” in SSDR that I hope can be addressed in the near future.
Tim K9WX
- 398 Community Topics
- 678 The Flea Market
- 192 SmartSDR+
- 392 SmartSDR API
- 96 Aurora
- 988 Maestro
- 963 Genius Products
- 353 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
