Another cool thing about v3.x software
David Hickman
IF you are a digital **** and like to listen/do the 75m nets at night, here is a way for you to do both at the same time.
I am running a 6300 with a laptop AND a maestro. I also have a separate RX antenna hooked up to the transverter port.
Note you can do this with two laptops, a laptop and an iPAd, and a Mastro. The idea is that you have two completely separate ways to access your radio on the desk and you have a separate RX antenna.
On your digital station operate as normal, except click the FDX icon on the bottom. This enables full duplex.
Now on the second device ( a maestro in my case) operate however you want to. Make sure that you tune on both sides or use a resonant TX antenna.
Now you can operate both at the same time and when transmitting the other console will only be affected if you are on a harmonic or too close to the transmitted signal.
I have found that I can even do digital on 20 and operate on the other side of 20 with tolerable interference. When on separate bands things just work.
Usually, I am running **** or on rare occasions FT8 on 40/80 while hanging out with the guys on 3.916 at night.
I can not wait for the software to stabilize.
2
Curious, please describe how you set transverter settings for this. I suspect you put transverter on 75m and set offset to 0 (zero), is that correct (away from radio, otherwise I'd just try it)...1
How are you running FDX on a 6300 ? Thought you needed a 6600 or 6700 to do FDX ?
Transverter settings:
Software 3.0.19
Antenna: Pixel Loop Connected to XVTR port
1. Name: Pix - this gets INVALID in red.. ignore it.
2. RF Freq: 0.0000
3. if freq: 0.0000
4. LO Freq: blank
5. LO error: 0
6. RX Only: ENABLED
7. Max Power: 0.0
8. Rx Gain: 0.0
TX Band Settings:
PIX - RF Power: 0, Tune PWR 0, PTT Inhibit: Checked
Slice Settings:
RX Antenna ( BLUE ): XVTR
TX Antenna (Red): ANT1
I have the RX antenna set up as outlined in another message in this thread, running multiple consoles ( multiFlex) ( Smart SDR for digital on laptop) and a maestro for ragchewing.
Working fine on a 6300.
I think you may be able to do the same thing by just selecting XVTR for the RX Antenna (without setting up a XVTR). Does this not work for you David?0
- 371 Community Topics
- 93 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 35 Aurora
- 246 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 451 Remote Operation (SmartLink)
- 996 Third-Party Software
