Yeasu M-100 and Flexradio
Hani - OD5TE
I got a Yeasu M-100 microphone and can’t seem to get it to work on my Maestro. Any advise on the settings? I am assuming it works with Flexradio..... Thanks un advance. 73 Hani / OD5TE
you need the optional power supply kit for that mic to use it with the flex gigaparts make a note at the bottom of the m-100 add about using it with other radios1
Thank you Ray. Even though they only listed some Yeasy radio and no mention of Flexradio. Will check out the kit. Tnx es 730
I just bypass the built in pre amp and it works fine with my 6400. I figure there is enough equilization in the Flex.1
Thank you Craig. Are you using it through the Maestro?
When connected to Maestro, I am not able to activate the PTT and no audio goes through if MOX is pressed.0 -
Gents, that you for your kind support. I did a lot of testing and was finally successful to make the M-100 work with the Maestro. In summary, even though Maestro has 5V on one of its pins, but once the M-100 is connected the voltage drops to 2V. There is definitely a need for external power source instead of the Maestro power source and Microphone works like a charm. I put together a cable taking its power source for a battery pack.0
- 353 Community Topics
- 617 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 174 SmartSDR for Maestro and M models
- 413 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 375 SmartSDR API
- 9.2K Radios and Accessories
- 23 Aurora
- 217 FLEX-8000 Signature Series
- 923 Maestro
- 897 Genius Products
- 325 Tuner Genius XL
- 116 Antenna Genius
- 285 Shack Infrastructure
- 200 Networking
- 138 Contesting
- 758 Peripherals & Station Integration
- 978 Third-Party Software
