Yeasu M-100 and Flexradio
Hani - OD5TE
Hani - OD5TE Member
edited May 2019 in Maestro
I got a Yeasu M-100 microphone and can’t seem to get it to work on my Maestro. Any advise on the settings? I am assuming it works with Flexradio..... Thanks un advance. 73 Hani / OD5TE
  • Ray Sylvester
    Ray Sylvester Member
    edited May 2019
    you need the optional power supply kit for that mic to use it with the flex  gigaparts make a note at the bottom of the m-100 add about using it with other radios
  • Hani - OD5TE
    Hani - OD5TE Member
    edited May 2019
    Thank you Ray. Even though they only listed some Yeasy radio and no mention of Flexradio. Will check out the kit. Tnx es 73
  • Craig Williams
    Craig Williams Member ✭✭
    edited May 2019
    I just bypass the built in pre amp and it works fine with my 6400. I figure there is enough equilization in the Flex.
  • Hani - OD5TE
    Hani - OD5TE Member
    edited May 2019
    Thank you Craig. Are you using it through the Maestro?
    When connected to Maestro, I am not able to activate the PTT and no audio goes through if MOX is pressed.
  • Hani - OD5TE
    Hani - OD5TE Member
    edited May 2019
    Gents, that you for your kind support. I did a lot of testing and was finally successful to make the M-100 work with the Maestro. In summary, even though Maestro has 5V on one of its pins, but once the M-100 is connected the voltage drops to 2V. There is definitely a need for external power source instead of the Maestro power source and Microphone works like a charm. I put together a cable taking its power source for a battery pack. imageimage
