Smartlink setup quit working ver 2.4.9 and 3.1.19
Steve
my system is a laptop running Win 10 (all updates). neither version allows the "setup smartlink" button to operate. Earlier SmartSDR would not connect to radio. The radio is on, and not connected in the remote shack. Maestro and radio (6500) operate normally on internal network.
Remote network is up and running several other operations ports 4993 and 4994 are open. The remote operation used to work, so i know it has to be something dumb but i am stumped right now.
Check your network configurations. Make sure you do a DHCP reservation in the router so the radio always gets the same LAN IP address and check the port forwarding to make sure it is forwarding to the radio.
In SmartLink setup go into the network settings and click the test button and see what the results are.
The remote system used to work and has stopped now. I use fixed IP. Firewall has specific routing of ports 4993 and 4994 to the 6500. Firewall config has not been changed. Internet was moved from DSL to fiber in my remote location, so that is the change action. All other internet seems to work normally.
At this point I cannot get smart sdr to even accept a request to “setup”. Clicking the button has no effect. I suspect a recent change to Windows is the base problem.
On the other hand it does work from my iPhone using the cellular modem. So further testing will have to wait till Tuesday when I go back to work. At that point I can try iPhone on both cell and WiFi to see which works.
Any other ideas? All help greatly accepted0 -
I am wondering if your Internet provider may be using NATted IPs, meaning they use 1 public IP for many houses. Then when you add your router to the mix you get double NATting. Since you are saying this started since the move to fiber youshould contact your ISP and ask. Maybe they can forward the needed ports. Make sure you tell them the ports and which is UDP and TCP. Good luck! Dave wo2x0
No, the problem child lives in my office. We have 5 static IP’s and generally do e-mail, web, name services in house. In theory double NATing shouldn’t effect anything other than transit time. Now a firewall at the ISP level that they don’t tell you about could be another thing. However we are, with the static ports, supposed to have a wide-open pipe to the world, but it is AT&T. I have verified all ports open.
I’ve got to put the back-up windows drive back in my Linux unit and try that. I always suspect windows and their weekly patch files but it happened right when 3.0 was released.0
- 379 Community Topics
- 636 The Flea Market
- 141 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 272 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
- 462 Remote Operation (SmartLink)
- 793 Peripherals & Station Integration
