Is it possible to connect a straight key along with paddles?
Jim Miller
I currently use CW paddles on my Flex 6400M but would also like to have a straight key ready to use. Is there any way to connect a straight key and keep the paddles on also?
Yes, connect it to the Accessory connector on the back panel. Pin 4 is the keying input, and use one of the ground pins (pins 5, 6, 7, 8 or 10) for the ground side. See section 7.3.5 of your Flex-6400M / Flex-6600M User Guide.
Thanks Craig! I am still new with the Flex and having some problems gettings connected. I really appreciare your reply.]
Jim-WA5EF0 -
You could also fabricate/buy a Y cable. Of course you would need to see if the Settings....Radio Setup....Phone/CW....menu selections need to be changed depending upon which you want to use.0
I considered that but wouldn’t that require a reconfiguration of the settings for CW? Thanks-Jim0
My Accessory input already has a connector installed for my amplifier, so in looking at the settings there does not seem to be a way to use the front panel key receptacle for a straight key. Is that correct?0
Yes there is a way. From the SmartSDR User Guide:
"To transmit in CW mode using the keyer built-into the Flex-6000 radio, you will need either a straight key or an iambic paddle. Refer to the FLEX-6000 Hardware Reference Manual for wiring instructions.
To use a straight key, uncheck the IAMBIC control in the CW transmit panel."
However, you can use the Accessory connector for both the amplifier and CW key input (and any other functions provided) simultaneously. Just add the necessary wires to the connector.
- 379 Community Topics
- 636 The Flea Market
- 141 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 272 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
- 462 Remote Operation (SmartLink)
- 793 Peripherals & Station Integration
