vodafone tethering
marco rinaldi
hey guys.
6700 and maestro resh owner.
On domestic wifi all ok, when I try to connect to iphone vodafone tethering the mastero it connects to the tethering wifi but no radio available.
Are there any parameters to set?
Many thks
IK2LFF
Marco
Many thks
IK2LFF
Marco
Most likely ports are closed on the tetherd device I use att cell phone and pay the hotspot tethering and ports are blocked it will not work either1
I was suspecting it. Do you know if I can solve on the device settings or do I have to call vodafone? Tks0
I would call them see if they will open ports my cell carrier said no0
I doubt that AT&T blocks the Maestro port but anything is possible. In my case, using an AT&T hotspot, I think it's more likely double Network Address Translation (NAT)is the culpret. Checking myip.com, my public IP through the hotspot is 107.77.205.144 but the hotspot says that it's IP address is 10.20.126.238, which is a non addressable, non public, internal LAN IP address. Therefore the 1st NAT was in the router at AT&T. This means the hotspot is part of a LAN subnet. The Maestro reports its IP as 192.168.1.90, another IP reserved for internal LAN, non public use. That's normal out of a router but it's a 2nd NAT that the packets don't follow to the Maestro.0
Well if you find a way to make it work with att hotspot please let me know I gave up.0
Does anyone happen to know which, of the three IP address mentioned above, the SmartLink server uses to pass radio packets to a Maestro?
I don't understand why SmartSDR on a PC receives the packets fine but they fail to get to the Maestro in identical environments. The MTU is set to 1000 for both tests. Thank you!0 -
Works fine with my AT&T Nighthawk LTE hotspot.
https://www.att.com/buy/connected-devices-and-more/netgear-nighthawk-lte-mobile-hotspot-router-512gb-steel-gray.html
P.S.
SmartSDR works fine on my Windows laptop connected in the same manner to the same 6300 via the AT&T hotspot with double NAT & similar IP addresses as described above.
That makes me wonder what the difference is between the Maestro and the laptop.0 -
What works fine, Maestro, iPad/iPhone or SmartSDR on a Windows PC? Thanks!0
Vodafone too said no. That’s a real pity.0
Good test, I’ll try on my laptop and tethering on vodafone iPhone. On maestro doesn’t work and (given the vodafone reply) it won’t work. But I won’t give up. May be with a sort of vpn?0
- 333 Community Topics
- 601 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 399 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 170 FLEX-8000 Signature Series
- 912 Maestro
- 52 FlexControl
- 880 Genius Products
- 318 Tuner Genius XL
- 116 Antenna Genius
- 279 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 730 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 949 Third-Party Software
