Remote Antenna Switch
Rob, I actually like the relay clatter, it gives some feedback that something is actually happening...SmartSDR gives no clue whatsoever of either an antenna change, or which antenna is currently selected.
Roberto,
Set pin 1 as frequency based from 14.000 to 29.999 (antenna A)
Set pin 2 as frequency based from 1.800 to 7.300 (antenna
Both active high0 -
Hello Steve and thanks for your help.
Sorry but it seems does not work anyway. In order to be more precise about my setting :
Pin 1--> Enabled , active high , Tx slice freq.range low 1800000000 , hi 7200000000
Pin 2 --> enable active high tx slice freq range low 14000000000 , hi 29900000000.
The only doubt is that active , would be stay on LOW as in this way I can hear and work with my antennas,.... but this is not THE problem . The problem is that remote switch does not change relay at band (freq..range) changing.
Please note that frequencies sintax has ben taken in "automatic" as I wrote 1.800 , 7.20 etc.
also please note that in case I set "BAND" instead of freq.range it work without problem (but as said I have not output enought to caver all of my band/antenna)
It could be a problem of revision ? Currently I'm under 1.10.16.174.
Thanks for your help and patience and
73 de IZ2ODM Roby
Hello Bob!
i know your post was a long while back. but can you give me a little more on what relay board you used and how to wire to do what you described!, Im a show me guy, so if you had a pic that would be nice. thanks in advance for your time!0 -
Hi, I bought that board some 15-years ago. I've been looking for the past day or so but either I can't remember the name or it's no longer being sold. Just about any board with SPDT relay contacts will do. Couple it with an antenna switch that's got a wired remote switch with a common and one activation wire per relay. Wire it up like I described & it should work fine.0
Thanks Bob I ordered both, the Denkovi's and the sainsmart, both on slow boats from China! Looking forward to see what I can destroy! Not fooled with many relays, I would assume the 12 volt go to common and use NO side for each relay0
OK, got sainsmart board in, hooked up to flex. Recognized right off, have relay working, the way I see it is if I use a tri band beam I would have to use 3 relays, one for each band, be nice if you could have more than 1 selection on each relay in software. Any thoughts or suggestions. Thanks0
Sorrry, I don't operate that way so my input won't be of any value. I switch mine by hand from a remote app on my phone or PC, not by output from the radio. Hopefully others with experience having the radio switch antennas will be of help to you.0
That's OK, that's not a biggie, particularly interested in the suggestion you made about wiring and still have knob control if needed. Any pics? Thanks for your time in replying, not done a whole lot with relays in the past0
I have a MFJ-4726. I am thinking of using Ham Radio Deluxe to change the frequency, change the antenna and rotate it with my Flex 6500. The MFJ-4726 has RJ45 connectors and the Flex can send a signal to it via a parallel connection from the PC to the MFJ-4726. What need is the pinout for the MFJ-4726 or a schematic. Can't find one on the MFJ site of searching on the internet. Can I just assume it is Pin1-to-pin 1 all down the line?
- 631 The Flea Market
- 123 SmartSDR+
- 195 DAX
- 39 Aurora
- 950 Maestro
- 925 Genius Products
- 337 Tuner Genius XL
