Need the latest SmartSDR and Power Genius Software?
SmartSDR v3.1.12 and the SmartSDR v3.1.12 Release Notes. | SmartSDR v2.6.2 and the SmartSDR v2.6.2 Release Notes.
SmartSDR v1.12.1 and the SmartSDR v1.12.1 Release Notes. | Power Genius XL Firmware v3.4.16. | Power Genius XL Utility v2.2.10.
Flex Genius XL power supply failure
On power up self test shows power supply failure. All other tests passed. I just received the amp today. Any ideas other than contact Flex
- 69 Community Topics
- 1.9K New Ideas
- 118 The Flea Market
- 5.4K Software
- 4.9K SmartSDR for Windows
- 35 SmartSDR for Maestro and M models
- 84 SmartSDR for Mac
- 143 SmartSDR for iOS
- 149 SmartSDR CAT
- 66 DAX
- 278 SmartSDR API
- 7.1K Radios and Accessories
- 5.8K FLEX-6000 Signature Series
- 553 Maestro
- 14 FlexControl
- 721 FLEX Series (Legacy) Radios
- 149 Power Genius Products
- 117 Power Genius XL Amplifier
- 10 Power Genius Utility
- 22 Tuner Genius
- 41 Shack Infrastructure
- 22 Networking
- 88 Remote Operation (SmartLink)
- 50 Contesting
- 127 Peripherals & Station Integration
- 61 Amateur Radio Interests
- 403 Third-Party Software
Keith - AC9S
This is a too-common shipping fail for the PGXL. However, for most hams, it is usually an easy field fix. The standard caveat of making sure you disconnect the amplifier from AC power also applies. If for any reason you find stripped screws or cannot loosen and slide the power supply back into its socket, the amp will need to be returned.
The brackets that hold the power supply in place have been redesigned and we are awaiting a shipment to send out to all PGXL owners.
Best,
Dan
Dave WA6DKN .
Maybe Flex needs to add an UPS driver to the alpha team for shock impact testing.
1) Inspected for any physical damage.
2) Bench-tested to ensure each meets acceptance specifications.
3) Repackaged for shipment to customers.
These tests are in addition to those performed at the factory
Best,
Dan
Looks like 4O3A/Flex redesigned the bracket that failed and will also send them to all buyers per Dan’s first post. Haven’t seen any postings of shipping-related damage issues other than the bracket.
