Flex Genius XL power supply failure
Trader Dave
On power up self test shows power supply failure. All other tests passed. I just received the amp today. Any ideas other than contact Flex
Open a help desk ticket.0
I have had the same issue before. There may be a simple fix. If your comfortable opening up your amp (Hex head screws on the sides) you can probably solve this quickly. With the cover removed you will find the main power supply on the right side as you face the front of the Amp.. There has been an issue with excessive handeling in shipment where the power supply has slipped towards the front of the Amp. Try pushing it towards the rear of the Amp as it has most likely slipped out of the rear connector thus leaving it unpowered. In some cases you may have to loosen the bracket on the top of the power supply to be able to slide it to the rear. It only had to move ⅛ -¼ “ to be disconnected. That solved my issue and has not been a problem since. It’s a great Amp, hope that solves it! Watts K4QJZ0
Nice to hear from someone who finally received a PGXL 73 Bill W9JJB0
Yes, glad to hear amps are again shipping. Hopefully I'll get mine soon.
I much prefer the way Alpha shipped their amps - with the transformer in a separate package. Note I just sent my "standby" KPA500 back for some factory work and they recommended taking the transformer out prior to shipping. Lots of mass!
Keith - AC9S
The power supply in the PG XL is a switching supply and does not have the weight of the old Alpha/Peter Dahl transformers.
Yes, Watts is correct and his directions for a fix are also correct.
This is a too-common shipping fail for the PGXL. However, for most hams, it is usually an easy field fix. The standard caveat of making sure you disconnect the amplifier from AC power also applies. If for any reason you find stripped screws or cannot loosen and slide the power supply back into its socket, the amp will need to be returned.
The brackets that hold the power supply in place have been redesigned and we are awaiting a shipment to send out to all PGXL owners.
Best,
Dan1 -
I want FedEx for shipping and will Pay extra for that shipping carrier and Not accept UPS for shipping My PGXL The new thicker bracket was to prevent This disaster is a must if the PGXL since The PGXL is so fragile for shipping PGXL Power Supply dislodges and damages Unit during shipping Hopes FRS inspects each unit Before shipping out any more PGXL’s !!!!!!!!! Unacceptable for a $7K Amplifier for FRS to do otherwise My SPE 2K Amp was double boxed and the Packing that FRS is not acceptable in lieu of the mechanical bracket Design flaw in the PGXL 73 Mike0
The Flex amps are very well packed as well as all their products. Every now and again we here of a damaged PGXL from very a high impact. Under normal handling this damage would never occure.0
Thanks to K4QZE for identifying the problem. I loosened the screws on the side of the power supply and pushed the supply more than 1/4 inch towards the back. That fixed the problem. Thanks to all replies.
Dave WA6DKN .0 -
The shipping gorillas! Dave wo2x0
Glad to hear it worked, now the fun begins. Unfortunately there is not much anyone can do to control how something is really handled. The amps are doubled boxed and isolated with soft foam all the way around to absorb most shocks. Enjoy your weekend, Watts K4QJZ0
Thank you0
Maybe Flex needs to add an UPS driver to the alpha team for shock impact testing.
Maybe manufacturing quality control need to add a steps to secure parts inside of Amp for shipment. Parts or connectors should not move during shipment or movement0
When PGXLs arrive they are typically palatized. The current inbound acceptance process for each unit is:
1) Inspected for any physical damage.
2) Bench-tested to ensure each meets acceptance specifications.
3) Repackaged for shipment to customers.
These tests are in addition to those performed at the factory
Best,
Dan0 -
Looks like 4O3A/Flex redesigned the bracket that failed and will also send them to all buyers per Dan’s first post. Haven’t seen any postings of shipping-related damage issues other than the bracket.
The 4 screws on the side of the power supply were not tight This caused the power supply to slip out of place. I fixed the problem by pushing the power supply back in place and tightening the screws. Flex should address this problem by adding another **** and bracket at the front of the power supply to prevent slippage. There may be other solutions.0
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
