Smartlink Question
Peter WB6POT
Today my ISP had to change my static IP (at the shack site) to a different static IP. Everything came back up as expected (ip cameras, rotor control, switches, etc.) but I can no longer remotely connect to my 6300. I can TeamView into the shack computer and operate the radio that way - just can't load SmartSDR from a remote site.
I don't understand the handshaking that happens with Smartlink. If the shack IP changes, do I need to unregister and re-register? If not, what would cause this problem?
This may shed some light on the problem: I just checked the Radio IP address that Smartlink shows prior to trying to connect remotely and noticed it's different than my new IP. My WAN IP address ends in ****.1 and the radio IP shows ****.142. I double checked my router, and it does show ****.1. Where is Smartlink getting it's IP from?
Peter - WB6POT
Peter - WB6POT
The radio sends updates to the SmartLink server with that information. It may be that you are going to need to reboot the radio to get it to pick up the new network settings. Another consideration is whether the radio's IP changed and if any port forwarding rules need to change as a result.0
I tried rebooting twice with no change.
The radio's local IP is reserved and has not changed. The port forwarding is also unchanged. It's definitely due to the incorrect IP Smartlink is getting. Is there a way I can manually tell Smartlink my true IP?
I'll check with my ISP to see if there is something going on with his network. This is a wireless 5 ghz service.
Peter - WB6POT0 -
I have seen this happen as well at my ISP. While I don't have a Static setting from my ISP about every 3 weeks they change my IP and then 3 weeks later, they change it back to what it was. Rebooting the radio doesn't seem to help.
Rebooting the pfSense Router cleans it right up. Not sure exactly why other than it might be a TTL issue on the DNS server somewhere. I'm blaming this on the Firewall to some extent.
Mike va3mw
All working now. It was on the ISP side. Got this explanation from him: It was a miss configuration on our side. The public IP's where all being natted to that .142 address you saw. Thanks, Peter - WB6POT1
Glad you got it sorted out. This is the challenge we all have with remote stations. We can't control anything between the 2 routers we have control of.
- 328 Community Topics
- 594 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 397 SmartSDR for Mac
- 260 SmartSDR for iOS
- 247 SmartSDR CAT
- 179 DAX
- 369 SmartSDR API
- 9.1K Radios and Accessories
- 15 Aurora
- 162 FLEX-8000 Signature Series
- 909 Maestro
- 51 FlexControl
- 873 Genius Products
- 312 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 135 Contesting
- 725 Peripherals & Station Integration
- 136 Amateur Radio Interests
- 945 Third-Party Software
