Left sidebar minimized
Dan KG0AQ
How do I get the left sidebar to be minimized or "tucked in" when opening SmartSDR? I have tried saving the "tucked in" side bar with global and other profiles with no luck. It always comes up with top arrow pointing left showing menu titles. Does anyone know how to pull this off? TIA
73 Dan KG0AQ
73 Dan KG0AQ
2
I've never been able to get it to remember that settings. Have tried the same as you. Hope someone has a solution. Thanks for posing the question.0
That's something that should go into an "ini" file, along with other info like window size and position and maybe the default profile name. My opinion based on old-timey linux and Windows experience.0
I have found that the pop-out "Radio Control Panel" (I have mine popped out to the Right Side) is remembered as the last status it was in when I closed SSDR. If you want it "popped in" then use the little arrow to pop it in, then close ssdr. The next time you open it, it will be within the main window. If you pop it out and then close SSDR, it will be popped out the next time you open it.
I have not recently tested it as part of Global Profiles. I know Global Profiles remember the various slices, pans, & frequencies, But O don't remember if they remember pop-out status of panadapters and control panels.
Ken - NM9P0 -
Yes, SSDR remembers the state and position of the Radio Control panel but not the small panel with +RX, +TNF, etc. I wouldn't exactly call this a bug, just probably something no one thought was important enough to fix. A minor annoyance for those of us who don't keep SSDR running 24/7,0
Ken,
You stated "If you want it "popped in" then use the little arrow to pop it in, then close ssdr. The next time you open it, it will be within the main window."
I am running 2.49 and no matter what position the bar is closed with it comes back on popped out with the arrow pointing away from the panadapter. That is my observation when I restart my SmartSDR software.
73 Dan KG0AQ0 -
I haven’t checked it on 2.49. I’m on 3.0.19.... Perhaps they changed it in the upgrade. I’ll check release notes later and see....0
using 3.0.19 on my 6k7 the bar is displayed as ever before irrespective of whether the bar was hidden or not when closing SSDR0
- 335 Community Topics
- 602 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 178 FLEX-8000 Signature Series
- 913 Maestro
- 882 Genius Products
- 319 Tuner Genius XL
- 116 Antenna Genius
- 280 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 736 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 950 Third-Party Software
