iOS version of Flex SSDR software, shared license
Dan Trainor
Member ✭✭✭
Hello, I have a Flex 6400. I am sharing it with a friend. We are in different states. I have iOS SW which I purchased from my Apple account. Does my friend have to purchase same separately? Or can he somehow use my purchase license and install iOS app on his iPad? I am running version 2.4.9 (not ver 3). Thanks in advance. Dan
He will have to purchase it using his apple id.1
Your purchase of iOS SSDR is tied to your Apple account, and any device that shares your Apple ID can share the app. If your friend wants to remotely operate your Flex 6400 he can either download and install SSDR on his windows computer, or he can purchase iOS SSDR for his iOS device. Of course, the third option is to loan him your iOS device iOS SSDR can not be shared, exchanged, or transferred across Apple accounts.1
OK thanks guys. He purchased it with his Apple ID account and we registered it with my radio. It is working (sortof). It will run for 5 or so minutes then freeze (not disconnect). No way to unfreeze it unless he hits the disconnect button and re-connect again then it come back for a short while then freezes again. Concicently, I had the same exact symptoms this morning (before we even go him set up). So, we are thinking there is a bug - but I have been using iOS version for a month without problems. Puzzling. Anyone see this type of issue recently? A freeze??? Dan0 -
He just switched over iPad from Wi-Fi to cellular and now works as expected. But, with using his home Wi-Fi it only works for say 5 mins then freezes (but does not disconnect). Cellular WAN connection works fine. dan0 -
Strange. You would think the home Wi-Fi would be better than a Cellular connection. I had similar issue with the iOS app. It requires a VERY robust low latency network connection ! Turning off bluetooth on my iPad also helped.1
You may need to reboot his or your internet modems and/or routers. There may be a glitch, buffer overflow, buffer bloat, or other situation.
You may also have developed a bad connection in a CAT5/6 cable somewhere in one of your systems.
My suspicion is that it is on your system since you both have had connection problems.
Also check to make sure that the Display settings have the waterfall rate turned way down or off if your homes upload speed is borderline. My system is so slow that I turn the waterfall OFF when running remote over the WAN.
@Joe, I also have had recent "chop-chop" problems when trying to use my bluetooth headphones on my iPad.0
- 361 Community Topics
- 622 The Flea Market
- 8.1K Software
- 48 SmartSDR+
- 6.3K SmartSDR for Windows
- 180 SmartSDR for Maestro and M models
- 417 SmartSDR for Mac
- 269 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 378 SmartSDR API
- 9.2K Radios and Accessories
- 27 Aurora
- 226 FLEX-8000 Signature Series
- 929 Maestro
- 904 Genius Products
- 327 Tuner Genius XL
- 118 Antenna Genius
- 289 Shack Infrastructure
- 203 Networking
- 141 Contesting
- 985 Third-Party Software
