Selecting XVTRs via API commands
Jens SM6AFV
I have setup SmartSDR 2.4.9 on my new Flex6600 for 10 vhf/microwave transverters.
I have since before a separate C# application for transverter switching & Az/El control/display.
Now I want to set up SmartSDR for the correct XVTR from my own C# application by adding API
control of XVTRs.
I have played around a bit with with the K1PGV C# Test program to test commands for XVTR activation. The test software work well but when I add a button for activation of a specific XVTR
nothing happends, no errors. The txtXVTR.Text is updated.
The code I added after the Mode buttons is:
private void btn1296_Click(object sender, EventArgs e)
_thisRadio.ActiveSlice.Panadapter.XVTR = "1296";
txtXVTR.Text = "1296";
Any clue what I am doing wrong?
/Jens SM6AFV
Running the Test software under v3.0.19 did not worked ok so I downgraded to v2.4.9 again
control of XVTRs.
/Jens SM6AFV
After digging into the API Wiki and logging/testing the communication with WireShark/Putty I found the solution.
The code for selecting transverters can be
_thisRadio.ActiveSlice.Panadapter.Band = "X2";
where X0, X1, X2 is the transverter in Transverters setup order.
Jens - SM6AFV0
- 372 Community Topics
- 96 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 938 Maestro
- 54 FlexControl
- 783 Peripherals & Station Integration
- 997 Third-Party Software
