Sdr remote with cluster spots
When operating Sdr remote I am looking for the simplest way to add DX cluster spots in the remote pc - I have this running in the shack on V3, no problem - while away I am looking at what interface to run to feed the spots onto the display. Just for info I am running a Panasonic Toughpad FZ-G1 - excellent device with sunlight viewable touch screen and built in 4G network access - superb for portable - shame Apple can’t do an “outdoor IPad “like the toughpad Phil G4UDU
Hi Phil
I have a slice master running on the local PC connected to my 6700 in my shack. When I connect remotely to the radio via smartsdr those sports has also appeared on the remote panadapter
SDRBridge also do that trick but is only display the spots from cw skimmer
Marcin M0GZR0 -
Hi Marcin I can do the same with MacLogger Dx in the shack and that will transfer the dx cluster spots. I have full remote power switching so when I am away for a time I turn on the power then activate the remote power up on the 6400 - but the problem is there is no local cluster input - so running the application away from home I need the portable dx spot input. I would prefer to use the iPad but that limits me to SSB and CW and I cant see it in sunlight ! I would like a cluster program that I can filter the spots like DX heat. https://dxheat.com/dxc/ I can run this simultaneously portable on the web browser - I just like to keep everything as a slick operation and that’s the reason for getting the spots on screen. Phil G4UDU0
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 280 FLEX-8000 Signature Series
- 958 Maestro
- 935 Genius Products
- 343 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 142 Amateur Radio Interests
