Problem installing PowerSDR v2.8.0
I have been trying unsuccessfully to install PowerSDR v2.8.0.122 for a Flex-5000 radio.
PC's hardware and system settings:
HP Envy Desktop 750-514
Processor Intel Core i5-7400 CPU @3GHz
Windows 10 Home Version 1803
From the KE9NS website, we downloaded the PowerSDR 2.8.0 full install. In the processes of installing the software, it also installed the Flex firewire driver to v4.1.3.17357 and did a firmware update for the Flex-5000. One suspicious thing that happened during install was a message that said:
".NET Framework 4.5.2 or later update is already installed on the computer."
After digging through Registry, I determined that the OS already has installed .NET Framework 4.7.2. I was able to click past the message and it continued with the install, so I don't know, but it doesn't appear to have been a problem.
After installation of the software, updating the Firewire driver, and updating the firmware, we start PowerSDR for the first time. Immediately we get an error message:
"Unhandled exception has occurred in your application."
The full details are:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IO.FileNotFoundException: Could not load file or assembly 'AutoItX3.Assembly, Version=3.0.0.0, Culture=neutral, PublicKeyToken=a646454c8d475470' or one of its dependencies. The system cannot find the file specified.
File name: 'AutoItX3.Assembly, Version=3.0.0.0, Culture=neutral, PublicKeyToken=a646454c8d475470'
at PowerSDR.Console.Console_MouseEnter(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnMouseEnter(EventArgs e)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at PowerSDR.Console.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLMSoftwareMicrosoftFusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLMSoftwareMicrosoftFusion!EnableLog].
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.3394.0 built by: NET472REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Any help with resolving this issue would be greatly appreciated.
Glen Kesselring,K0JGH
My best suggestio is to first make sure this is not an I/O errorto the FireWire card or PSDR issue. Turn the radio off or unplug the FW cable reboot the computer just to make sure all is reset, try the install again. Then open PSDR, see if it will at least open the demo mode.. Let us know what happens, you may have to reload .NetFramework .0
Thanks for the suggestions, Dudley. One other experiment we did was to install PowerSDR v2.7.2 which is working. Also, the radio came with an installation disk which had v1.18.6 which also installed OK (although it complained about wanting .NET Framework 1.1.4322 which we got off the CD). So, it seems to be something related to the v2.8.0 install.
We will try the sequence you suggested and report back. Thank you!
Glen K0JGH0 -
Just to follow up.... we are still seeing the error using V2.8.0 even when starting in demo mode.0
I guess wait for some answer from Darren. :-)0
Darrin KE9NS posted a new installer for the v2.8.0.full download (the green download button)on his website which fixed our problem. Many thanks for the quick turn around on a holiday weekend.73 Glen0
[{"insert":"Greetings All\nI have a similar problem ,My pc won't install Power Sdr 2.8 but it installed version 2.7. I clicked on version 2.8(orange block) for full install. Pc build is a older machine.2.9 Ghz intel dual core processor 4 gigs of ram ,1 gig hard drive, Cronos firewire card and Win 10. Software is 64 Bit ready but 32 bit installed. I Have a 250 gig SSD drive with Win 7 loaded on it will try it and post results.\nThanks 73\nNaz\n"}]0
[{"insert":"Ok my fault Windows 7 needed service pack 1. It installs fine. Just found out my pc will just barely run the Flex 5000 ...so Amd Rysen here we come. \nMany thanks to Darrin for the advice much appreciated. \n73 ALL \nNaz\n"}]0
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
