AG8x2 works erratically in remote op w v.3
edited April 2019 in FLEX-6000 Signature Series
I just experienced this strange phenomena. Maestro on 20 m and SSDR PC on 40 m. AG connected via BCD to USB to Flex. AG indicated "red flags" on antenna selection and no antennas assigned . BCD indicated same bands so that is why red flags. Then when changing frequency on SSDR slice AG suddenly reacted and assigned antennas. For a while. This repeated itself several times. Ranko 4O3A was present on PC via Team viewer and could not see what was wrong. So here is an issue. I will test more thoroughly. All works fine in v 2.4.9. The set up is remote over VPN.
Welcome!
  • Member ✭✭
    edited April 2019
    Kari - Are you using the latest version of the AG8x2?
  • Administrator, FlexRadio Employee admin
    edited April 2019
    Kari,
    I think the Antenna Genius is going to need a firmware update to support SmartSDR v3.0.
  • Member ✭✭
    edited April 2019
    Hi Eric, yes it look like that. Happy Easter and thanks for all good work with v.3. Can it be Xmas in April?
  • Member ✭✭
    edited April 2019
    I have the original hw version but latest sw. I will replace it with AG 8X2 V.2 plus today. Guess sw is the same so issue will remain...
