cw keyer weight adjustment
kv5v
Is there a way to adjust the keyer dot-dash (weight) ratio? As a CW op I appreciate the memories and easy speed adjustment, but I'd prefer being able to change the ratio from 1:3 to one that lengthens the dashes a little.
3
Unfortunately, no. I wanted a "1/2" space for certain cituations but no go.
They have the spacing set for the perfect code spacing according to the spec for CW.0 -
Yes. The character spacing is also fixed, but the weight adjustment is most important. Not having a "perfect" fist, I'd like to be able to change it. Wish it weren't necessary to spend more money to fix this omission. Will have to add an outboard keyer.0
All the Japanese radios have had variable dash/dot ratio for a long, long time. It is different than "weight". I don't think any American radios have it. Not many keyers have it. The Micro-Ham keyer has it. It makes CW very musical. My preferred ratio is 3.6 to 1.
Thanks, Charles. Good point. I've always appreciated being able to adjust the dot-dash ratio in my Japanese radios. Doing this allows you to make your sending a little less machine-like and more personalized. My favorite ratio is around 1:3.3, but it changes with my mood. Ah but then, who writes letters by hand and in script any more? Maybe we should let this fade away along with teaching kids "script" in schools. Hi!
My KX3 allows changing the ratio, so the K2, KX2, and K3S probably do too. The K1EL keyers also have it. The Elecraft rigs were designed by guys who actually operate low-power CW portable, so having to make this adjustment was a given for them.1 -
My call sign... KC9EI... is often mistaken when using the built-in CW transmit mode. The E and I often become an S to the listener. Obviously the faster the speed the bigger the problem. I don't have an issue sending manually, probably for obvious reasons, but it would be nice to be able to tweak the spacing just a teeny tiny bit.
I've heard that there are hardware-related reasons the CW weight can't easily be changed in the 6xxx series radios. But I've also heard, and possibly misunderstood, that the Maestro contains a K1EL keyer to satisfy us quirky CW ops. I'm told that "accessory" is selling well, so maybe there are more of us than you'd think. Hi!0
Us CW ops have always had ways of adjusting the weighting of our keyers, and we should not have to defend why we want to be able to do that! Flex needs to provide that option; end of story.
:( there are so many bell a withels around the Felx but the ratio can't be set. It is for me a pain....1
Been using an external K1EL (K16) keyer for years to have wt adjustment. Internal keyer is rarely used.
The Flex 6000 series allows the use of external keyers. I don't use the built-in keyer option.
I prefer the external sidetone and adjustable weight of my trusty Daiwa.
- 379 Community Topics
- 631 The Flea Market
- 123 SmartSDR+
- 193 DAX
- 39 Aurora
- 948 Maestro
- 925 Genius Products
- 337 Tuner Genius XL
