using FlexLib: how many pan adapters are available
Jim Shaffer
Is there a way, using FlexLib, to tell how many pan adapters/slices are available without having to parse the radio's model string?
I need this information when I connect.
Jim,
There are both max and available values for slices and panadapters in the discovery packets. However, we don't currently parse these values into the radio object in FlexLib as we don't utilize the information. This is something that could be changed fairly easily if necessary.0 -
Thanks Eric, but I discovered I don't need this info.0 -
Eric,
What about populating the PanadapterList collection? That doesn't seem to be working with v2.5.1.
Mark, I'm using FlexLib 2.5.1, and the PanadapterList is being populated. I'm curious what you're showing for PanadaptersRemaining?0 -
I think the problem is timing. If the GUI client is running when the FlexAPI client is connected, PanadaptersRemaining is correct, but PanadapterList does not show any current panadapters. If you change the number of panadapters after the FlexAPI client is connected, the PanadapterList is update with all panadapters.0
Interesting. I guess I'm always changing the number after the connect. My client sets IsGUI.0
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
