iOS issue with wifi and smartlink
On both wifi's, I can open SSDR iOS and it runs great for about 5 minutes. No stutter and runs just like I am at home. After 4-5 minutes, the software just freezes. Panadapter, waterfall, audio, etc just stop. If I hit the Disc button, I will disconnect and then I can reconnect and I am good for another 5 minutes and the same thing will occur after 4-5 minutes. Everything just freezes and the audio stops. If I turn off the wifi on my phone and run off cell data, all is good. I can run all day on cell data. I also have no issues at home via the wifi (not using Smartlink). Any ideas on what would cause the software to just stop like this? I'd rather not use my cell data when I have good wifi here at the office.
If I bring my laptop to the office, I can run all day running SSDR for windows on each of the Spectrum wifi services.
K4QXX
With all the V3 conversations, I wanted to bump this back to the top. I am still having the smartlink issue with my iPhone If I connect my iPhone to my vpn using my office internet, I can run the iOS app all day but if I use smartlink, it runs great for 4-5 minutes and just freezes. I can hit the disconnect button and then reconnect and it will run again for 4-5 minutes before it freezes again. Same internet connection is fine if I use my vpn connection with iOS. I can run DogparkSDR and SSDR all day on the internet connection in my office using Smartlink. This only seems to be an issue with the iOS app. Does anyone have any suggestions?
Hello,
Fyi
I found that if I'm using Smartlink on my iphone 6 I have to disconnect my wifi on my iphone to stop choppy audio.
running v3.9.8 on phone.
Rob
I am having this exact same issue. On my iPhone and iPad at my Son’s home, connecting via smart link, the display freezes at 5 minutes. Both devices do this and its the exact same amount of time. 5 minutes. Both apple devices are on OS15.x with the latest App Store updates.
I can use SmartSDR on my Mac without any disruption. Both the Mac version and the Windows version in a Fusion Virtual Machine. I ran my iPhone on Cellular and no issues. I ran my iPad through my iPhone hotspot on cellular and no problem. I have used Smartlink at other locations and not had issues so it seems to be related to my Son’s network. It’s a Netgear ORBI. The ORBI is “bridged” to a Comcast xFi running in modem only mode. My son has a OpenVPN server. When I got back home, I tried connecting to my Son’s VPN, and then SmartSDR to my home. Same freeze at the 5 minute point. Any ideas - Is there a function/setting within Smartlink that times out after 5 minutes?
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
