V3 and Spots?
Dwayne_AB6A
Updated to V3 over the weekend but my Spots are now missing. Is it me or are others having issues with Spots??
Dwayne,
Spots should be working better than ever in SmartSDR v3.0. Can you tell us some more about how you are setup? What application are you using to supply the spots?0 -
WSJTX and CW Skimmer are my two primary apps. Slice Master stopped working for me with V3 so that may have something to do with it.
Windows 10.
The reason I asked my question is just to confirm if its just me affected. Your response confirmed I need to do some more digging on my side.0 -
I might suggest that you try using CW Skimmer with sdr-bridge. It now supports spots. See this thread: https://community.flexradio.com/flexradio/topics/sdr-bridge-v3-beta-2-available-now1
Will do! Thank you!
What I have seen many times, is sometimes when things dont work, if you uninstall the SPOT software, and re-install it everything works normally.. After major Windows 10 updates, I find I have to re-load the ICOM Drivers for my IC-R8600 so I can use HDSDR software..
Just an FYI...
Robert0
- 382 Community Topics
- 638 The Flea Market
- 144 SmartSDR+
- 433 SmartSDR for Mac
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 57 FlexControl
- 932 Genius Products
- 303 Shack Infrastructure
- 141 Amateur Radio Interests
