Version 3 SSDR not starting properly
AC9S
Hello,
I am running a 6700, Maestro (original version) and SSDR Version 3 on Windows 7. Accessed locally, through a GS108 switch, SSDR appears to start, the chooser appears, but when I choose the 6700, the application never appears on the screen, nor does the program icon display on the task bar. However, I can hear sound from the radio and the application shows up on task manager. I cannot bring it to the foreground or maximize it from the task manager - both of which I can do with DAX and CAT.
The Maestro works just fine and yesterday I think SSDR when I first loaded it worked as well. I am able to tune the SSDR receiver from Logic9, but of course that is the limit of my RX functionality from that package.
The application is definitely running, but with the exception of Task Manager it is invisible to Win7. The only way I can get rid of it is to **** it from Task Manager. I have tried every permutation that I can think of powering down the 6700, computer, and Maestro.
Help!
Keith - AC9S
Help!
Keith - AC9S
Keith, One possibility is the application is offscreen. Press thee Windows Key and Right Arrow to see if that’s the case. Does the program icon appear in the task bar? 73, Mack W4AX Alpha Team0
Sounds like the SSDR window is open off your main screen.. try one of these 3 methods to snap it back to your viewing screen..
https://www.nextofwindows.com/3-ways-to-deal-with-off-screen-window-in-windows-7
Hi Mack, The program icon does not appear in the task bar. By the three Windows keys I assume you mean CTRL, Windows, and alt - plus the right arrow.
I tried that plus throwing in the fcn key on my wired keyboard. Nothing show on the screen.
Thanks -- Keith - AC9S
Hi Larry,
I tried these - since the program icon doesn't show on the task bar they didn't work.
Appreciate the input.
Keith - AC9S
Is there any chance you have set up virtual desktops? I'm just taking a stab because that could explain the lack of taskbar icon and the application being off screen. I use virtual desktops a lot so I thought I'd throw it out there.0
Hi Geoff,
No - I do not have a virtual desktop going, not intentionally anyway.
Thanks for the input.
Keith -AC9S
As a quick check, hold down the Windows key and then the Tab key.0
Thanks Geoff,
That is a nice tip, but all windows showed up except SSDR which was still decoding 40m. Bizarre!
The sequence is:
1. Clean start up of everything - radio , computer - Win 7, switch.
2. Start 6700
3. Start SSDR V3
4. Chooser shows
5. I pick my 6700 & connect
6. The chooser immediately appears to minimize, but does not show up on task bar
7. 6700 is receiving
8. SSDR shows up as an application in task manager - along with DAX and CAT which have autostarted
9. When I **** SSDR application from task manager it disappears from the application list, but the radio still plays
10. The SSDR task still shows up on task list and the radio only stops playing when I **** the task from task manager.
11. If I start SSDR, Maestro, then another instance of SSDR the chooser says there is an instance already running on my computer.
Looks like I have a Ghost!
Keith - AC9S
Keith,
My suggestion would be to reset the SmartSDR settings file.
1. Close SmartSDR for Windows.
2. Open a file browser and go to %appdata%FlexRadio Systems.
3. Make a copy of the SSDR.settings file.
4. Delete the SSDR.settings file.
5. Start up SmartSDR for Windows (which will create a new settings file).
The settings file contains information about where each of the Windows was last used, which could be involved in this issue.0 -
Thanks Eric,
That did the trick. I appreciate the help.
Keith - AC9S
I have a similar issue, using a 6300...everything starts automatically, but I never get to see smartlink, so I can't set it up...any suggestions?
If Auto Connect is functioning, but you want to get back to the radio selection screen (SmartLink Setup is also there), you can use the Settings -> Choose Radio option in the menu at the top left.0
Eric, thanks for spending so much time on the community lately, it's been noticed.1
- 375 Community Topics
- 104 SmartSDR+
- 425 SmartSDR for Mac
