record button not working on V3
KI4P
anyone tried the quick record button? on my 6400 after upgrading, got numerous comments on audio not like it was on V 2. so i thought i would record and listen, never got record to work, works like a champ on V 2, switched back and it works, any ideas,
Were the comments regarding audio after the upgrade positive or negative?
just said audio was different! so i thought i would listen and see what difference was but couldnt get to work on V30
maybe this is the same issue. My record works, I just can't monitor when I play it.
Well, kinda sounds like it, hope that gets fixed pretty quick. Very helpful when checking audio. Thanks0
This was supposed to be fixed, in this release. It is mentioned in the change log...I hope it is fixed in V2.50
Works fine on 2.40
possibly you need to import your profiles to regain your prior audio EQ and Mic settings
- 244 Community Topics
- 481 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 162 DAX
- 348 SmartSDR API
- 8.5K Radios and Accessories
- 745 Maestro
- 41 FlexControl
- 720 Genius Products
- 387 Power Genius XL Amplifier
- 249 Tuner Genius XL
- 84 Antenna Genius
- 225 Shack Infrastructure
- 150 Networking
- 120 Contesting
- 114 Amateur Radio Interests
- 805 Third-Party Software
