record button not working on V3
KI4P
KI4P Member ✭✭
anyone tried the quick record button? on my 6400 after upgrading, got numerous comments on audio not like it was on V 2. so i thought i would record and listen, never got record to work, works like a champ on V 2, switched back and it works, any ideas,
  • Pat N6PAT
    Pat N6PAT Member ✭✭
    edited May 2020
    Were the comments regarding audio after the upgrade positive or negative?
  • KI4P
    KI4P Member ✭✭
    edited April 2019
    just said audio was different! so i thought i would listen and see what difference was but couldnt get to work on V3
  • Larry _ NY8T
    Larry _ NY8T Member ✭✭✭
    edited April 2019
    maybe this is the same issue. My record works, I just can't monitor when I play it.
  • KI4P
    KI4P Member ✭✭
    edited May 2020
    Well, kinda sounds like it, hope that gets fixed pretty quick. Very helpful when checking audio. Thanks
  • Bill -VA3WTB
    Bill -VA3WTB Member ✭✭✭
    edited April 2019
    This was supposed to be fixed, in this release.  It is mentioned in the change log...I hope it is fixed in V2.5
  • KI4P
    KI4P Member ✭✭
    edited May 2020
    Works fine on 2.4
  • K1UO Larry
    K1UO Larry Member ✭✭✭
    edited April 2019
    possibly you need to import your profiles to regain your prior audio EQ and Mic settings
