record button not working on V3
KI4P
anyone tried the quick record button? on my 6400 after upgrading, got numerous comments on audio not like it was on V 2. so i thought i would record and listen, never got record to work, works like a champ on V 2, switched back and it works, any ideas,
Were the comments regarding audio after the upgrade positive or negative?
just said audio was different! so i thought i would listen and see what difference was but couldnt get to work on V30
maybe this is the same issue. My record works, I just can't monitor when I play it.
Well, kinda sounds like it, hope that gets fixed pretty quick. Very helpful when checking audio. Thanks0
This was supposed to be fixed, in this release. It is mentioned in the change log...I hope it is fixed in V2.50
Works fine on 2.40
possibly you need to import your profiles to regain your prior audio EQ and Mic settings
- 371 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 247 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 996 Third-Party Software
