Flex 3.0.19
Member ✭✭✭
FLEX 3.0.19 and WSJT-X work like a champ together , now we need a contest for Ft8
Welcome!
  • Member ✭✭
    edited September 2019
    James, could you share your WSJT-X setting which work with the new software? Since upgrading I cannot get the radio interface right for WSJT-X although my FLDIGI and Winlink applications work fine. I'm using a Flex-6400M.
    Tim N9PUZ
  • Member ✭✭✭
    edited June 2020
    the one thing I found I had to fix was in CAT the STATION had to be set to my station after that it work like a champ. So check that
  • Member ✭✭
    edited April 2019
    FT8 DX Contest 2019 -- April 13 and 14 2019
    https://europeanft8club.wordpress.com/
  • Member ✭✭
    edited April 2019
    Also these FT8 contests.
    https://www.rttycontesting.com/ft8-roundup/
    CQ VHF/UHF Contests allow FT8 mode
  • edited April 2020
    I have had no issues so far with my install or operation of version 3. I have used it simultaneously on my Maestro, Ipad and Surface Pro 3 at the same time.
    Working great so far . . . Thanks Flex
  • Member ✭✭✭
    edited April 2019
    Nice Steve, you have a nice setup there.
  • edited April 2019
    Thanks Bill... We’re in the RV right now and have the Flex in a storage bay with a Cat 6 to the router in the RV with Maestro hooked to router. I sit outside at picnic table with IPad or use Maestro when inside.
  • Member ✭✭✭
    edited April 2019
    That IS a nice setup Steve. I sold my A class 13 years ago but I know exactly where the 6K box and Maestro would go. I Kinda miss it.
