FLEX 6400M bug (no working S meter and panadapter)
Валерий Смирнов
I buy flex 6400M for contest position EW6W - 1 day ago
After start - i cant see station on panadapter and levels on S meter
When preamp off - S-meters - working good but sometimes I dont listen station
FLEX 6500 -- work exelent!
WHAT ME DO??? I BUY BUG FLEX???
SEE video -- https://youtu.be/k_1rrO-0oNk
Try doing Hard Reset, shown in Manual, radio should come back on at 14.100MHz
then see if that helped.
73's
Bret
WX7Y
no help restart
are you running SmartSDR? , What version?
is it only to M screen not working?
no worked 2.x version - I am upgrade to 3.x, also bad((( no work on SMART SDR on PC also(((
Try to go to Version 2.3.9 on Flex6400 Reboot -Hold Power On CW - 400Hz BW No Preamp My Noise Floor is -123 here with Hex Beam Hear Beacons If Noise Floor High - Maybe Heatsink fell off A/D Chip - Gets to hot Receiver can go deaf Try bypassing your External Antenna Switch And feed same Antenna Feed from your 6500 into 6400 to rule out bad switch or Coax line to Radio 73 Mike0
another 6400 work good! on my antenna) S meter work
IS BUG FLEX
WHY FLEX factory no tested radio before sale??? I buy 2 days ago!
ITS CONTEST POSITION and I HAVE more flex radio
www.ew6w.com
Perhaps you should start a help desk for a fast response.1
help desk no answer
What me do whith bad flex 6400M???? I buy 3 days ago((((
- 337 Community Topics
- 605 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 401 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 185 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 185 FLEX-8000 Signature Series
- 913 Maestro
- 885 Genius Products
- 319 Tuner Genius XL
- 116 Antenna Genius
- 281 Shack Infrastructure
- 197 Networking
- 137 Contesting
- 740 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 952 Third-Party Software
