Flex 3.0.19
James Kennedy-WU5E
Member ✭✭✭
FLEX 3.0.19 and WSJT-X work like a champ together , now we need a contest for Ft8
James, could you share your WSJT-X setting which work with the new software? Since upgrading I cannot get the radio interface right for WSJT-X although my FLDIGI and Winlink applications work fine. I'm using a Flex-6400M.
Tim N9PUZ
the one thing I found I had to fix was in CAT the STATION had to be set to my station after that it work like a champ. So check that
Also these FT8 contests.
https://www.rttycontesting.com/ft8-roundup/
CQ VHF/UHF Contests allow FT8 mode
I have had no issues so far with my install or operation of version 3. I have used it simultaneously on my Maestro, Ipad and Surface Pro 3 at the same time.
Working great so far . . . Thanks Flex1 -
Nice Steve, you have a nice setup there.0
Thanks Bill... We’re in the RV right now and have the Flex in a storage bay with a Cat 6 to the router in the RV with Maestro hooked to router. I sit outside at picnic table with IPad or use Maestro when inside.0
That IS a nice setup Steve. I sold my A class 13 years ago but I know exactly where the 6K box and Maestro would go. I Kinda miss it.0
- 379 Community Topics
- 634 The Flea Market
- 139 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 270 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
