v3 problem
Richard Zalewski
Smart SDR running showing 14.040.175 freq....radio shows 14.028.280. When I transmit it is on the radio's freq.
Worse is when SSDR is set to 40M the radio is still on 20M and that is where it is transmitting
multiFlex on radio has a check for SmartSDR Maestro...I do not have a Maestro. Can not uncheck it to check Smart SDR win:Dell-Desk0
Think things are under control...the selection of radio in the SSDR was going to a Maestro which did not exist.0
Richard, It sounds like you may have found a bug (mentioning Maestro when one isn't present). Note that we do use the same software on both the Maestro and the M Model front panel, so it may stem from that. But that's no excuse for using the wrong name. Let us know where you saw that (or even better, a screenshot) and we'll see what we can do to fix it up. Thanks.0
- 656 The Flea Market
- 438 SmartSDR for Mac
- 385 SmartSDR API
- 52 Aurora
- 969 Maestro
- 941 Genius Products
- 345 Tuner Genius XL
