v3 problem
Richard Zalewski
Richard Zalewski Member ✭✭
Smart SDR running showing 14.040.175 freq....radio shows 14.028.280.  When I transmit it is on the radio's freq.
  • Richard Zalewski
    edited May 2019
    Worse is when SSDR is set to 40M the radio is still on 20M and that is where it is transmitting
  • Richard Zalewski
    edited May 2019
    multiFlex on radio has a check for SmartSDR Maestro...I do not have a Maestro.  Can not uncheck it to check Smart SDR win:Dell-Desk
  • Richard Zalewski
    edited May 2019
    Think things are under control...the selection of radio in the SSDR was going to a Maestro which did not exist.
  • Eric-KE5DTO
    edited April 2019
    Richard,  It sounds like you may have found a bug (mentioning Maestro when one isn't present).  Note that we do use the same software on both the Maestro and the M Model front panel, so it may stem from that.  But that's no excuse for using the wrong name.  Let us know where you saw that (or even better, a screenshot) and we'll see what we can do to fix it up.  Thanks.
