RX_A/ANT2 mutes ANT1/ANT1 on TX - Flex 6600
WT2P
Member ✭
I am running into this weird situation and hopefully someone has some hints how to troubleshoot:
Slice A:
ANT1/ANT1 - 40M
Slice B:
RX_A/ANT2 - 80 - MOX (no power out) Slice A signals mutes
RX_B/ANT2 - 80 - MOX (no power out) does NOT decrease signals on Slice A
Any combination where RX_A is selected causes the other slice/antenna to mute signals
RX_A port is working fine and I use a DXE RX antenna port protector. Any ideas? I had been switching between diversity RX
WT2P
Slice A:
ANT1/ANT1 - 40M
Slice B:
WT2P
If I read this correctly:
RXA uses the same SCU as Ant1, so yes, RXA will be muted if you transmit on Ant 1. RXA will not be muted if you TX on Ant2.
Mie
- 657 The Flea Market
- 438 SmartSDR for Mac
- 203 DAX
- 385 SmartSDR API
- 52 Aurora
- 295 FLEX-8000 Signature Series
- 969 Maestro
- 944 Genius Products
- 467 Remote Operation (SmartLink)
- 809 Peripherals & Station Integration
