Spontaneous Mode Change in FT8
Bill
I am running a Flex 6400, SmartSDR 2.4.9, WSJT-X 2.01 and JTAlert 2.12.1. No additional control software loaded, although I do use HRD logbook running without the HRD control module. Lots of contacts on FT8, but I continue to have spontaneous mode changes from DIGU => USB. The net impact of this change is likely minimal, probably the last .300 khz of band pass, but I don't understand why this continues to happen. There are some much older posts regarding this, but none seem to apply to me. Is anyone else experiencing this phenomenon, or understand why the SDR mode will not stay where it is set (with no change in band) using WSJT-X?
Are you running with “None”, “Fakeit” or “Split”? I suppose it would be possible that if you were using “Split”, the switch to a second VFO/Slice by wsjt-x could be triggering the change. What happens if you force “None”, or “Fakeit” (that is assumeing you are not already doing that)?0
This is a WSJT configuration issue. If the radio changes modes, then something commanded it to change modes externally.
This is one of my setups. Make sure you have Mode set to None.
Mike va3mw
Can someone explain what is "fake it"1
“None” means leave the frequency alone and just send the audio tone. “Fake it” means adjust the VFO frequency AND the tone so that the resulting signal is in the middle or “sweet spot” of the passband, preventing transmission of nasty harmonics of the audio signal. “Split” means do what “Fake it” does, except use a second VFO / Slice, instead of adjusting the frequency of the VFO in use. In all cases but “None”, wsjt-x sends CAT commands to the radio to adjust it.1
Mike,
You nailed it! Mode in WSJT-X was indeed set to USB, so the 6400 was just doing what it was told to do!
Problem solved....
Thanks and 73s
Bill,
What are you using for rig in WSJT-X?
All,
1) There should be no reason to use anything but 'None' with Flex.. The total digital audio stream does not generate audio harmonics and the TX passband is flat, and thus no need for keeping the TX tones in the 'sweet spot'.
2) The bug in WSJT that effected the 'Flex 6xxx' interface was fixed in WSJT V2.0.1 and has been very reliable. However you may need to use the Kenwood TS-2000 rig type is you're running CAT through Smartlink.
3) I prefer to use PTT via CAT for PTT method. PTT via RTS has no advantage when using virtual serial ports ( the data is never converted to a serial stream with virtual serial ports and thus there is no serialization delay ).
AL, K0VM
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 93 Aurora
- 988 Maestro
- 963 Genius Products
- 353 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
