As a follow up to DIGU or USB for use with FT8 I have found that while DIGU is great for RTTY opera
As a follow up to DIGU or USB modes for use with FT8, I have found that while DIGU is great for RTTY operation its use on FT8 is OK but does have a built in limitation. While allowing me to set DIGU up to view (and have WSJT-X decode) 7.074 to 7.078 MHz using a stretched 3 KHz Filter (out to 4 KHZ) It will only transmit out to 7.077 MHz leaving the top 1 KHz as just a receiver. Using USB (with a 4 KHz filter) I can view and transmit anywhere in the band (7.074/7.078 or any other band that has 4 KHz of room).
I know that JT65 and JT9 or some other digital modes have been unofficially assigned to some of those frequencies. But from my observations the upper 1 KHz of 40 and 20 meters is little used since the FT8 mode was introduced while the lower 2.5 KHz is totally packed. I even saw some activity below 100 Hz a few days ago.
Their is bound to be Pro and Cons about this but I don't see a major problem with using the entire 4 KHz on the 40/20 meter band or using USB mode with an appropriate configured Profile (no audio processing applied).
Al, N4AB
Al, N4AB
Al
Check your TX bandwidth setting, Look at the lower portion of the Phone panel in SmartSDR panel menus. That setting can be stored and controlled using a Digital, Mic profile, which of course you will need to setup. Afterwards, usually the persistence memory "Always Active" should apply the Digital Mic profile automatically when your on that frequency and set to DIGU mode.73, Jay - NO5J
Set DIGU with a TX and RX filter of 5kHz. I always work with this setting.
DIGU bypasses all SSB voice settings and thus is the best choice for all digital modes,
except RTTY, which has it's own mode settings, with a twin peak filter.
See also:
https://www.flexradio.com/downloads/how-to-guide-ft8-setup/
Alex - DH2ID2 -
OK Jay and thank you. I forgot that I had set my transmit bandwidth to 100 to 2900 Hz. Sometimes a quick rap on the head will help ****. The appropriate profile for FT8 should include the bandwidth as it should for all the modes.0
Al
Not ****!!! no final exams until the learning is all done.73, Jay - NO5J
- 379 Community Topics
- 634 The Flea Market
- 135 SmartSDR+
- 198 DAX
- 43 Aurora
- 956 Maestro
- 301 Shack Infrastructure
