Problems with WSJT-X
K0SWT
K0SWT Member
edited March 2020 in FLEX-6000 Signature Series
I'm unable to get my flex 6300 to work correctly with WSJT-X. I am using slicemaster and everything is configured correctly. For the past week I have been trouble shooting why it won't work. I am able to use it to send wspr it works fine. It shows recieve and says decode but, nothing shows up in the panel on the left side. I am running meinberg for time sync. Any ideas? Thanks in advance and 73's. K0SWT
  • Neil D Friedman N3DF
    Neil D Friedman N3DF Member ✭✭✭✭
    edited October 2019
    What version of WSJT-X?
  • AH0U
    AH0U Member
    edited June 2019
    Can you see the green bar graph on the left side of WSJT and if so does it bounce up and down???
  • K0SWT
    K0SWT Member
    edited March 2019
    Yes it does.
  • K5CG
    K5CG Member ✭✭
    edited March 2019
    Do you have CAT control setup with WSJT-X such that when you select a band from the drop down control in WSJT-X, it changes the frequency of the Flex?
    More often than not with digital modes, the radio is simply not tuned to the correct spot.
  • Craig_KØCF
    Craig_KØCF Member ✭✭✭
    edited March 2019
    I repeat N3DF's question: What version of WSJT-X are you running? If it is not 2.0, you will likely see nothing decoded because the specification changed with v 2.0 and it is NOT compatible with older versions.
  • K0SWT
    K0SWT Member
    edited March 2019
    That was the problem. I uninstalled and loaded the updated version. Thanks all.
  • K0SWT
    K0SWT Member
    edited March 2019
    I updated to 2.0 and it is working fine now. Thanks all.
  • Maurice PC9T
    Maurice PC9T Member
    edited March 2020
    I have the same problem, already upgraded to the latest version of WSJT-X and version V3.1.8.
     I see activity in the waterfall and the reciving db meter is bouncing and decode is sometimes flashing but no reception under band activity.
  • AH0U
    AH0U Member
    edited December 2019
    Have you checked your clock??
  • Maurice PC9T
    Maurice PC9T Member
    edited March 2020
    I have timeserver:time.windows.com running last check was 1 week ago, but after synchronisation it's working again; tnx for the tip .
