Problems with WSJT-X
K0SWT
I'm unable to get my flex 6300 to work correctly with WSJT-X. I am using slicemaster and everything is configured correctly. For the past week I have been trouble shooting why it won't work. I am able to use it to send wspr it works fine. It shows recieve and says decode but, nothing shows up in the panel on the left side. I am running meinberg for time sync. Any ideas? Thanks in advance and 73's. K0SWT
What version of WSJT-X?0
Can you see the green bar graph on the left side of WSJT and if so does it bounce up and down???0
Yes it does.0
Do you have CAT control setup with WSJT-X such that when you select a band from the drop down control in WSJT-X, it changes the frequency of the Flex?
More often than not with digital modes, the radio is simply not tuned to the correct spot.0 -
I repeat N3DF's question: What version of WSJT-X are you running? If it is not 2.0, you will likely see nothing decoded because the specification changed with v 2.0 and it is NOT compatible with older versions.
That was the problem. I uninstalled and loaded the updated version. Thanks all.0
I updated to 2.0 and it is working fine now. Thanks all.0
I have the same problem, already upgraded to the latest version of WSJT-X and version V3.1.8.
I see activity in the waterfall and the reciving db meter is bouncing and decode is sometimes flashing but no reception under band activity.
Have you checked your clock??1
I have timeserver:time.windows.com running last check was 1 week ago, but after synchronisation it's working again; tnx for the tip .
