Slice-Master Set Up: HRD Logbook and CW Skimmer DAXIQ
Alan
Member ✭✭✭✭
Two questions for setting up Slice-Master 6000. Any help to resolve would be appreciated:
1- When attempting to start up CW Skimmer using Slice-Master, I get the error message, "DAXIQ Channel is not enabled". I have DAXIQ setup to channel 1 on the panadapter, but continue to get the error message.
2- Slice-Mater will not connect to HRD Logbook. The message, "Cannot Connect to HRD Logbook" displays on the bottom of Slice-Master.
Hi Alan,
Take a look in the DAX Control panel to make sure that DAXIQ channel 1 is enabled there.
For HRD Logbook, make sure that it is running and is listening for connections on port 7825. From Logbook's main menu bar, select Tools/Configure/Network Server
If you'd like your CW Skimmer spots to show up in HRD Logbook, you probably want to create a cluster entry for Slice Master's aggregation server.
But there are a half dozen other ways to make this happen too.
--Don
Do you have CAT open?
Slice Master doesnt use CAT.0
Try closing and starting DAX only. A couple times it got the CW Skimmer running. 73 Bill W9JJB0
Thanks Don
Both "problems" resolved with your help. On the DAXIQ, found channel 1 was not working. Switched to channel 4 and enabled per your note. Worked just fine.
Help ticket issued for help returning channel 1 to service. Pop up says DAXIQ cannot find the driver or the channel is in use.
k1bo I have been having some problems with slice master, wondering if you could give me some suggestions0
- 371 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 996 Third-Party Software
