Flex 6600 and WSJTX-FT8 Port settings
Arvind Mallya
I had my Flex 6600 working with WSJTX-FT8 but had to replace the laptop. When I went back to install FT8 I'm unable to match and assign the port from Smart SDR CAT to the PTT settings on WSJTX which is set to port 5. I'm attaching a photo of the display to the left is Smart Cat PTT set to Port 9, Windows is the center display port 9 serial port. On the right is WSJTX and set to Port 5. I'm unable to change the PTT settings to Port 9. Windows has assigned Port 5 to a wireless device. Any help is appreciated!
I have the 6700 but settings are similar I think?
This setup is very different than mine. Firstly, CAT is not using COM5. CAT uses the network. That's why it is grayed out.
Why don't you have the rig set for FlexRadio 6xxx?
Then you can set the Network Server to 127.0.0.1:60001 according to your CAT setup.
Kev K4VD0 -
You can't choose port 9 because the WSJTX PTT is set to CAT. This means the PTT is transmitted through the CAT port as a radio command. If you choose DTR or RTS, then you can select the Com 9 PTT port. Note that you do not have to choose Flex as the radio. Kenwood on a Com port works just fine.
Craig, I did not follow your response, so the settings on WSJTX PTT is not selectable as it defaults to Port 5 and Port 5 is already assigned by Windows to Sierra Wireless device. How does one change that?0
Arvind,
As Craig said, you have the PTT set to CAT command , not a separate PTT port, with Com7 set for CAT and PTT set for CAT, it should work set as a TS-2000, just restart WSJT. Use Kevin's suggestion of TCP control, then you need not worry about the Serial com ports.
Dudley
Dudley, so as I understand it , I set WSJTX PTT to DTR or RTS and select the PTT port 9 and it should work. Right now I'm receiving fine as it receiving on Port 7, but not transmitting PTT in Port 5.0
Hi Arvind
If you use SliceMaster, then it will handle all the setup of DAX and CAT in a few mouse clicks.
https://www.youtube.com/watch?v=_ww8CcGNAzg&t=4s
Have you given that a try?
I did not know about SliceMaster. So are you saying that also does the radio setup in WSJTX and Port setups?0
Yes it does. It is darn cool and just works. Don wrote it to be simple.0
I searched for a download on Flex Website, did not see it. can you post a link.0
Michael, After I rebooted this morning WSJTX setting for PTT port reads Port 9 and the PTT port on Smart SDR CAT is also 9. Hope to see some activity now and be able to transmit out0
Michael, Thank you for that link and program. I got the radio up and working FT8 in no time and got QSOs in Japan and Asiatic Russia. Slice-master program really simplified the complicated port settings. I'll post the settings and a snapshot of screen later.
- 376 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
