What type of Amp are you using??
Mike-VA3MW
I'm doing a poll on HF Amps
I would like to know which HF amp you are using and if it is CAT controlled.
Let me know!
73, Mike va3mw
Let me know!
73, Mike va3mw
4
I am using a PGxl - controlled via LAN by Flex 6600.0
AL-1306 but I gave up trying to get the cable and CAT commands to work. I generally only use it on 20 & 40 so I just switch it manually
2K-FA and yes1
KPA500 and a Alpha 99....KPA controlled by the USB cable.
Lou N2TU0 -
Hi Mike. I'm using an SPE 1.3K Didn't bother hooking up the CAT but it is available. What I really like about this amp - 1300+ watts out on ssb with 18 watts drive, very quiet, only weighs 17 lbs.
DX2400 controlled by the radio USB port. Probably not a well known amp.
Al / NN4ZZ
al (at) nn4zz (dot) com
6700 & SSDR-W V 2.4.9
Win10
KPA-500 no USB connection. Flex 6300. Works great!0
Running SPE 2K-FA, up to 1,500 watts SSB/CW, 1.2Kw on continuous modes like FT8, RTTY, etc. I'm using the cable sold by Expert Linears that connects the Flex radio directly to the SPE amp. When I power my radio up/down, the amp powers up/down with it automatically, band switching is automatic, and transmitter drive levels are automatically adjusted per band at each of Low/Medium/High power levels to drive the correct power out, without any ALC.
I really like the built-in tuner and 6 antenna ports.
Couldn't be happier.
Rick W5FCX2 -
My PGXL is ethernet controlled
My Expert2kfa is cat and USB controlled, and autosensing
My KPA500 is cat controlled, and autosensing.
SPE 2K and yes it’s CAT controlled. Waiting for the PG-XL.0
Using an Acom 2000a controlled by several CAT control programs. About to add a new RF-Kits B26 solid state amp. Running a 6600M.
73 - David, AG4F0 -
QRO HF-2000 and Amp Supply LK-550, both use 3-500Z's and fully manual. I've not been brave enough to try CAT with anything as yet. Prefer easy.0
Palstar LA-1K RF controlled.1
I am NJ5G, my HF rig is a Flex5000A, and the amp is a Tokyo Hy-Power 1.5 (a kilowatt amp. I do manual band switching.
NJ5G0 -
My RF Kit B26 arrived yesterday so should be live in a week or so!
Ameritron ALS-1300 w/ARI-500 for band switch control ..
Alpha 76PA .. no cat ..
KPA500 capable of auto band switching, but currently manually band switch, with my Flex 6600.
And I will LOVE to see the results of this poll.0 -
Real SO2R - 2x TRX and 2x PA
F6700 with B26-PA and F6600 with B26-PA
73 Chris, DL5NAM
SPE 2K-FA. It is CAT controlled and remote controlled via FlexLogger. I would have done a PGXL but it appears they are still very difficult to get.0
Heathkit SB-221. Can't figure out how to get the CAT to work properly.4
Saw this @ Dayton, thought it was expensive. Most everyone else has almost caught up.0
Using. a KPA1500 and the KPAUSB cable with a 6500 Rich n2ry0
Elecraft KPA500 with a FLEX6400 and Maestro.
Phil N3ZP
Ameritron AL-80B with an external QSK-5 for full break-in. Not CAT controlled. I change bands and tune the old fashion way.
PGXL Ethernet controlled. No breakdowns during Beta Testing.0
Expert 1K and Acom 1000 with 6700. Blyg amps are great, but in slightly different ways. Only drawback with Expert, old software for PC control. Doesn't work nearly as well as SW for the never models. Negative with Acom? No remote control at all. But a genuin easy to handle workhorse.0
OM Power 2000a+, CAT / Ethernet controlled. 73, Volker0
Hi Bill,
True on the price, had mine for 10 years now. Built like a tank, the combined weight of the power supply and RF deck is 145 lbs. Here is a link to my web page with more details if interested.
http://www.nn4zz.com/Prometheus.htm
Al / NN4ZZ
Win10
6400M with Drake L-7 (ANT1) and Henry 3KA (ANT2).
Both have Palstar 1KW HF-AUTO tuners.
NE7X...
Same here 2K-FA Running Remote with Remote Rig RC-1216H With CAT control from Flex 6600M Also have Don Tassel SPE Expert Amp Cable From Texas Works Great 73 Mike0
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 41 Aurora
- 955 Maestro
