Remote QTH Band Decoder MARK II with flex 1500
Miquel
Hi i have this band decoder https://remoteqth.com/wiki/index.php?page=Band+decoder+MK2 and i would like to use it with my Flex 1500 but i dont know how to get needed data from flex to band decoder.
Any ideas please ?
Any ideas please ?
Just a guess, but if you use its Kenwood mode, using ddUtil, you should be able to connect to the 1500 via CAT to get the frequency/band info.
Charlie KB8CR1 -
Hi, even simpler to use a USB to RS232 cable. Hook USB cable to Flex and the RS232 to the decoder. Choose then Kenwood setting in Banddecoder. There is a video (on their web page) showing a guy using it to steer a Marconi PA. Takes 5 min at most0
Kari, I think you might be confusing the Flex 6xxx series with the Flex 1500. Very different rigs.
Oh yes you are right. Missed that. Sorry.
After a rapid glance on Flex-1500 specs with Power SDR one way is following. With e g VSPE you set up virtual com ports that you tie to Com port of a physical PC RS232 card on the PC. The. You configure Power SDR for Kenwood CAT controll (TS-2000). Connect this RS-232 port to the corresponding port of the Banddecoder for a Kenwood. This will certainly work as Flex-1500 easily integrates with N1MM with VSPE. Another is to use a USB to RS-232 cable connected directly to the PC. The RS-232 goes to the banddecoder. You may use VSPE/Fabulatec to tie the com ports together.0
- 352 Community Topics
- 615 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 412 SmartSDR for Mac
- 267 SmartSDR for iOS
- 250 SmartSDR CAT
- 187 DAX
- 375 SmartSDR API
- 9.2K Radios and Accessories
- 22 Aurora
- 212 FLEX-8000 Signature Series
- 922 Maestro
- 894 Genius Products
- 323 Tuner Genius XL
- 116 Antenna Genius
- 284 Shack Infrastructure
- 200 Networking
- 138 Contesting
- 974 Third-Party Software
