Flex 6600m
Jimmy Collis
Cant get my spots to work on my 6600M been working flawlessly I have it enabled is there anything I'm not doing right internet working fine when i connect radio to PC
What programs are you using?0
Smart SDR V2.49 I usually dont use PC just rig but doesn't work on either one PC or just the radio with pc0
I meant even without the PC just the radio0
Jimmy
You do need a program to send the spots to the radio. N1MM, Slicemaster, etc.
https://www.flexradio.com/downloads/spots-feature-description-pdf/?wpdmdl=3097&refresh=5c7d58474...
Mike va3mw
I understand that Mike I've always just cut radio and when I enable spots in menu spots would appear on radio screen nothing is appearing no spots come on screen it's not receiving any spots0
Hi Jimmy
The spots are sent by some other PC program that you are using as that is the only way it can receive them. You must have had something else in play.
Mike1 -
Problem solved didn't have slicemaster on thanks for all the replys0
- 372 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 997 Third-Party Software
