How to set audio processor for DVK/DAX?
Andy - KU7T
I know how to use the processor, mic gain and EQ for the MIC or BAL inputs. I use low power and listen on a dummy load and hear the difference when changing settings. But, I do not seem to be able to adjust the same for the DAX stream of recorded messages. TX gain is the only one. How to adjust compression for DAX? Andy KU7T
I noticed the same thing Andy.
I think the only option would be to process the audio when you record it. All I see is the TX level in the DAX app controls.
Bill K4FX0 -
Is this what others are doing? Process in Audicity? Andy KU7T0
Yes, at least I do. Found it to be the best way of getting good audio out. Using N1MM and Audicity recorded files.
Always trying to adjust audio having my recordings sound as loud as when using the mic. Really dislike when answering someones recording and having a totaly different audio level coming back to me and/or even worse, a different voice. Only creating confusion and thoughts like "are there another station on the same QRG?" Who's answering me?
I played with this this morning. It appears that I was wrong. Processor and EQ is applied to the DAX TX stream as well. My main issue was I was running with too much gain and it sounded terrible. Now with tips being green and yellow but never red, all is good. Andy KU7T2
- 335 Community Topics
- 602 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 179 FLEX-8000 Signature Series
- 913 Maestro
- 882 Genius Products
- 319 Tuner Genius XL
- 116 Antenna Genius
- 280 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 736 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 950 Third-Party Software
